I'll let you all know. I bought a 6.5TD with 4L80E and 140k. Trans fluid black on the stick and rag used to wipe the stick to check level, trans not slipping or shifting strangely. Dropped the pan, cleaned everything inside that spray cleaner could reach, new filter then: disconnected return line from cooler, put a hose on it into a drain pan, added new fluid at the top while the old fluid drained into the pan with the truck running and trans in neutral, when the fluid coming out of the hose changed from black to clear red, stopped and buttoned everything up. Trans is working beautifully, just like new. Don't know the history of the trans. Could the black be the metal and clutch material from a new, or reman, trans being broken in? No way to tell, but the pan and filter were cleaner than many I've done this to. Never have had a high mileage car or truck react badly to this treatment, but none of them were slipping or acting strange - because I usually drop pan and do new filter at major services on whatever vehicle I've ever had all the way back into the early '70's so I've never experienced a auto-trans failure in all these years and many, many vehicles. 70's were easier with the old Mopar 727 cuz they had a drain plug on the torque converter.
Filter and fluid every 30 - 50k, and yes Jay-theCPA, it is messy, but it is much cheaper than a new trans. Nice thing about my trans is there is a drain plug on it so the mess is minimal. I work my things hard, but I take care of them, which is why I don't have any sad stories to tell - only questions to find out others experiences and solutions I've found that worked. That's is what this post is being offered for, take it or leave it, but don't give me a bunch of personal junk if you disagree - see "Lift pumps".
I haven't towed my 4 ton mini excavator on my 1&3/4 ton trailer yet. I let you know how it goes.
