D2 Cat
The truck is running real good. I've put about 130 miles on it since I've got it running. New GP's, OPS, return lines, rotors, front brakes, batteries, rebuilt injectors, cleaned the fuel monitor, new lines from FM, replaced driver door latch.
The heater is more heat then I can stand. I just replaced the blower high speed relay today. Prior to that fan worked on intermediate speeds only. Now it has an off position and gradually increases as dialed up, like it should.
The temperature control is what I need to check. How does it work? Where is it located (remember this is a '95)? Is there a bypass valve located up front by the firewall? What controls the temp.?
I've gotta get this fixed or I will have to disconnect the heater for the summer!!
