Tons of parts. (Help ID please)
Grayman
NorNev
Hello everyone,
I did an intro post but quick recap here. I’m from the Hummer forum and @Will L. suggested I come here. I recently stumbled across a TON of 6.5 engine parts that I’m looking to re-home.
Right now I am trying to figure out exactly what I’ve got and then I’ll explore options for selling / trading or giving away. If you’re interested in something please feel free to ID the part in this thread for everyone’s edification and then DM me for dibs.
I’ve only got one of what will likely turn out to be 3+ trailer loads of parts. Below I will post photos of what I managed to sort through today. I’ll add to this thread when I have time so go get and sort through more.
The back story on these parts is that they came from the former owner of an aftermarket Hummer parts company. He worked for Rod Hall racing then AM General after RH switched away from racing the hummers. These engines are all AMG test engines that never saw use outside of the dyno room. The former owner snagged them after testing was completed.
As best I can tell there were 4 total engines all for the HMMWV. I haven’t been able to surmise a date range for these engines but I’m hoping the collective wisdom here can help with that. There was obviously some skunkworks type testing happening as you’ll see from the later photos.
Here is the trailer when I started today…. I didn’t get through it all but I made a healthy dent.
First up are some IP’s. I believe they are all DS4’s. I couldn’t tell you anything more about them.
Next up are water pumps and crossover tubes. Two different types so please share if you know what’s what.
Next is accessory bracket trivia. Several different brackets
I’m told these are upgraded power steering pumps…
Now for the interesting stuff. There are several different turbos…
Manifolds which I think are all stock
And some that definitely aren’t.
If someone recognizes the casting numbers off a balanced flow waterpump-
That could help folks. I never remember the numbers on it.
The keen eye notices the cool banks style turbo manifolds that can adapt a side mount turbo into the pre turbo trucks and pre turbo hmmwv/hummers.
Idk if Grayman is allowed to say who he got these from but it’s someone that was big in hmmwv/hummers parts development. The ds4 stuff- could be stock or could be something bumped up in there.
Those silver colored (aluminum?) things in last two pics of post # 19-
Those have me really wonder what that is…
Alright today I got into the large parts. First up are the heads. I took lots of photos of these in the hopes y’all can ID them.
First head is labeled N/A
I think this could be the match to the other N/A head but I’m not sure.
The next two have injectors in them and I believe they are a set.
Last head
