NoInterstates!
Hey Guys,
Found this wrench at Lowes for about 40 bucks in Alaska. Probally 5 bucks down there in the lower 48. Last time,(the first time) I timed my truck, I had a real hard time with the bottom passenger IP nut. This little wrench makes both the bottom IP bolts about a 30 second job. Worked so good it would be wrong of me not to tell you all. Its called a GearWrench S-Shape. This set comes with 2 wrenches, one 17/15mm and one 13/15mm. Hope this helps someone. Take care all.
