G gerretw New Member Messages 2 Reaction score 1 Jun 9, 2021 #21 Or just remove the IP gear, rotate the pump 1 revolution, and reinstall the gear? G
MrMarty51 Well-Known Member Messages 22,654 Reaction score 54,079 Location Miles City, Montana Jun 9, 2021 #22 gerretw said: Or just remove the IP gear, rotate the pump 1 revolution, and reinstall the gear? G Click to expand... Would 1 revolution of the IP gear put the marks on the gear right back where the pump was before rotating pump shaft ? Best to remove timing cover, install new chain and sprockets and with marks aligned then set the pump to match.
MrMarty51 Well-Known Member Messages 22,654 Reaction score 54,079 Location Miles City, Montana Jun 9, 2021 #23 Best thing is to get the book and set the marks of the sprockets and pump gear to how it shows in the book.
NVW Well-Known Member Messages 9,890 Reaction score 5,007 Location Castor, AB. Jun 9, 2021 #24 This brings up a lot of user names long forgotten. Re read post #3, everything you need to know is there.
