Chevy3500
Ok i know alot about diesel engines and kknow that its commen for the oil to be black. But what is a safe way for my engine to clean the black stuff off of everything in my engine, without hurting the seals.
If the inside of the engine is black, at some point and time the wrong oil was used in the engine. Use the kerosene or even diesel fuel and just let the engine idle for 15 to 30 minutes then change the oil. Make sure to use a good diesel grade oil, it will keep the gunk in suspension instead of glued to the inside of your engine.
