devildogadam
Active Member
Well because of how cheap I am I went and bought a $37 fuel pump off ebay. My plan is to post some pics of the installation and show what kind of cheap little things I have done with it and then just see how long it last. The pump is a generic racing pump set up for hot rods, It is suppose to be able to flow 130gph at 14 psi (keep in mind that is for thinner gasoline not thick diesel). It cost a total of $47.97 with shipping and arrive on my door step in a timely manner. I asked the seller if it was able to run methanol and if it was a flow on fail pump, he could not answer either and had no clue what he was even selling, So that is a strike against it already but we will soon see how it works. I am hoping to also install a cheap fuel pressure gauge in line that will monitor pressure right before the injection pump. Also because I removed my tank sock I will be running a $5 filter from autozone that i plan to change out every other oil change or more often if needed. I know it might not be up to everybody's standards what I am doing but I am just going to give it a try and see how it turns out
