Tech2 scanner
I don't think Tech2 (OBD-2) tool is compatible with tech 1 (OBD-1) setup, iirc totally different comupters in PCM chip vs. flashed, also "pin out" of OBD1 plug is different from OBD-2.
For vehicle grounds there should be a post I wrote years ago showing all the vehicle grounds, one of the critical ones is the one on pass side rear intake manifold stud, that is the gnd for the PCM at least in OBD-2 trucks, I would have to confirm in same location for OBD-1 but I believe it is same location.
