mitchedo
I followed the timing instructions I could find that said to set the timing at 3.5 degrees, then perform TDC learn. I did that last night. I got perfect 3.5 timing, but my TDC was -2.46, and was setting TDC codes.
So, today I goes out to try and get TDC closer to -1.94. I moved the pump toward the passenger side about half a millimeter. The timing is (can't remember exactly) about 2.8 or so. My TDC is now -1.94 after performing a TDC learn.
The book calls for -0.25 to -0.75. It seems the ECM doesn't appreciate the -2.46 I had before. What is the reasoning behind setting it at -1.94? It is noticeably quieter at -1.94 than it was at -2.46.
This is a rebuilt engine with new timing set, new CPS. I'm using Autoenginuity to peform initial timing and TDC learn.
I've read and read and read, but I'm too stupid to get it, I guess.
