I decided to rebuild a 6.5 929 engine that I already had and swap this into our tahoe. I don't want to spend a whole lot of money on this. So far I took the motor apart and took the block to the machine shop to get it decked,and cam bearings installed. I got some Jasper heads at the junkyard that seem to be crack free. I'm not quit sure how I'm going to build this motor,but I'm thinking of block filler ,and compression ratio either stock or higher,and o ringing the block. The machine shop owner said if I block fill I will need to rebore the cylinders,which leads to new pistons that are not cheap, so I'm not sure yet what I will do. I'm also thinking of using 12.9 grade bolts for the heads and mains,and a home made girdle. This was a na motor out of a van, the bearings were dated 1995, but it had a mechanical db2 pump,and a crankshaft tone ring,but the crank sensor hole is plugged. I had a talk with Bill Heath about compression and I think I will listen to him this time,although I proved to myself I can make power with low compression it is not that practical for a daily driver. Bill said his race truck has 600 hp and 22.5-1 compression :smile5:
