the one thing that always stuck out to me was the need of a larger pulley on the alternator. using a larger diameter pulley makes the alternator spin that much slower and can effect the charging at idle.
Y’all need to concentrate in this point a bit more.
Why did GM bother spending all the money to make the different size pulleys?
It would be much easier and far more profitable for them to just use the gasser one but they didn’t. They could have set the ratio up at any one they wanted for the same cost but instead spent more for doing it where they did.
Change that pulley and avoid the charging hiccups, and avoid the rpm hiccups.
You can run the tachometer using an ESS, Engine speed sensor - it is an Oil Pump Drive with a 2 wires signal that comes out. Then build an adapter. That should only set you back around $600 by time your done.
You can buy aftermarket tachometers that have a sensor that goes on the alternator and a huge hose clamp around the alternator to hold it in place. Then mount the gauge on top of your dash. Those were $400 last time I saw, and reportedly last 4-5 years.
There is another one that is adjustable that you drill part of the bellhousing to install and it reads the flywheel teeth. You program in how many teeth the flywheel has, mount its gauge on the dash and good to go- those seem to last decades, cost around $1200.
From here, prices start getting mighty expensive.
My suggestion- buy the correct pulley.
