Mine was doing this too. R134 was low, vac'd recharge, re-did it a couple times with slightly diff lbs each time but never got it to do real well. High side is 'bouncing' a little bit and now neither system is cooling more than 20 degrees below outside (slightly better than before). Before; front was cooling 15 below outside and rear was probably 20-25. I'm going to change my orifice tube since it has a new compressor from the PO and it's cheap. It would be nice it that fixes it but my hopes are low.
I was thinking that I may put a valve in the heater hose to make sure I wasn't reheating my air in front with the door not moving completely. I am sure someone has better input than me but maybe we can help each other. I will let you know what happens.
