Bernie
Amateur Radio Operator - KJ4VOV
For the past month or two my 1999 GMC C3500 has had me thinking I was going to be rebuilding the diff soon. The typical scenario was, at first, driving at low speed, make a turn and it would "buck" a little. Not every time, more like just once every few days. I started trying to save some money at that point, figuring if I had to rebuild the diff I'd stick a Detroit Locker in it but, with the holidays getting closer, I haven't made much progress with that.
Then it seemed to get "better", and I didn't have a problem at all for a few weeks. (Figured I dodged a bullet there, and had a little more time to save some cash before the diff went)
Then, Monday, it did it again, HARD, almost like someone bumped me. Except the truck wasn't being driven. It was parked and idling in my driveway. Then it happened again, and the next day it did it again. Then it started happening at stop lights, with the truck very briefly "surging" against the brakes.
I'm thinking the problem is a leaky injector, but I'm not sure. It could also be a bad throttle I suppose.
History of the truck:
1999 GMC C3500, 6.5TD, 4L80E
The truck was a service truck from a county down in Florida, and seems to have spent most of its life parked in the garage. When I bought it in '08 it barely had 68K on the clock. Looking back over its service history though, I see the IP was replaced twice, at around 28K, and a history of fuel and/or fuel delivery issues. Since I've owned it I have had some issues, and replaced the PMD (with a remote unit) at 75K, the starter right after that, mater cylinder in '09, and the hydroboost this past spring. Currently the truck has just shy of 95K on it. I regularly use either PS or Howe's at every fillup, the fuel filter was changed last fall, and this current problem has been happening through at least four fillups from two different stations.
Also, from day one since I've owned it the truck would sometimes "surge" a little in reverse. Typically the way it happens is when I'm coming home and trying to back up my driveway (driveway has a 30 degree slope). I'll turn in to my neighbor's driveway across the street at an angle, put the truck in reverse, cut the wheels and start backing up mine, slowly. Just as the back starts to climb the hill the engine will surge a little, as if I lightly tapped the accelerator. This will typically happen once or twice a month.
So, any thoughts on this? Throttle? Injectors? IP? Any help at all will be appreciated.
