Acesneights1
I just searched aorund the old site but didn't find exactly what I'm experiencing on my 95. This seemed to get a little worse since the weather has gotten hotter. Basically the truck starts ok when cold(It never started super great). If you drive it for a little while and shut it off and say try to start it about 15 mins half hour or so later it cranks for awhile. Tonight it was worse that usual. I actually had to try it 3x before it finally started. Think the PMD would do that ? It's still on the pump. I was waiting for it to die. Once the truck finally starts it runs fine. LP is working and fuel seems good. Didn't stall when I opened the bleeder. No codes. All winter truck started with no issues even on really cold days. I'm just trying to figure out if the hot temps off hte motor are causing the PMD to screw up after I shut the truck down or is MY IP getting ready to go south ? I just cleaned all the grounds when I had the intake off. Got two matched INterstate batteries. Not the best but they work. I have GMTDscan but havn't used it yet. Any ideas ? I know I read over the other place a few people having this problem with no solution although tonight was the first time it actually gave the impression it wouldn't start at all. it was close to 100 degrees out today. I also did injectors last month,
