dusty
hi when i tried to start truck the starter made loud growling noises but would not turn the motor over pulled starter support bolt was missing one of the 2 bolts holding starter in place had broken off in hole cleared that installed new starter when i tried to start same thing happened have been told i could be the ring gear or the loose bolts cracked the block any info will be helpful thanks in advance
