Steve93mustanglx
Diesel fanatic!
Hey folks, today my Sub started back up after a quick 5 mile drive only to die when it rolled 3 feet. Yesterday, it died while idling at the cleaners. I was able to restart it yesterday, but no such luck today.
It has
- 2 new batteries (less than 2 months old, same brand).
- all grounds cleaned and tight.
- all new cables to batteries, starter, alt made from 2-0 gauge welders cable.
- 2 y/o PMD mounted remotely in bumper.
- oil level OK
- LP is working (fuel still shoots out of filter housing when vent is loosened).
- LP is wired with a relay to bypass the OPS
- fuel IS getting to injectors
- Voltage on batts: 14
- cranks when key is turned
- air filter removed, no change
- CDR brand new
- fuel tank is full, full filter is 1 month old, 600 miles tops
- engine is not hot. All hoses, water pump, thermostat, gaskets, band clamps, you name it were replaced last summer. It takes alot to get this truck to 200 degrees now.
I did pull 10,000 pounds last week several times, without issue.
It is located some distance away and will pull codes when I get back to it.
WHat am I missing? What should I check first?
It has
- oil level OK
- CDR brand new
