racer55
96 C3500 with NV4500 trans.
Question for the cluster/DRAC guru's,when traveling at speed on the highway my speedo works prefectly fine up to 100KPH-after that speed if I increase my speed to 110KPH the speedo reads 90KPH and continues to back off in an almost linear rate as speed increases.
Where do I start looking for this problem?
Speed sensor in the trans,grounds for the DRAC or wiring to the cluster.
The cluster was replaced for other reasons but the brand new cluster behaves the same way as the old one did.
I have yet to check the speed reported by the ECM to compare what it sees to the cluster since it is tough to drive that fast and monitor the laptop by yourself.
Minor problem but an annoying one.
