pacificdrumma
...for $150 I couldn't say no!
Found it on Craigslist, advertised as a low mileage engine removed from a CUCV Blazer. Appears to be in good shape. No oil leaks, paint on the oil pan and block, nothing visibly broken. The idea is to strip it to a long block to use to build a center mount turbo setup. Whether that turbo setup stays on the 6.2 or goes on my 6.5, I'll have the engine for the indefinite future and would like to know more about it. The air cleaner lid has it rated at 140hp, it has no EGR, and a 4521 spec injection pump. The block casting number appears to be 4022660, and I think it's about an '87 year engine.
Give me your thoughts on it and things I should know. I've had my 6.5 for 80k miles so I know the platform fairly well. Is this a good block? A good basis for a project? And can I test run it without a flywheel?
