Quadstar Tuning LLC
Quadstar Tuning LLC
Time to let the cat out of the bag!
I've been working on this for awhile and finally got a prototype working. My end goal is to develop as many of the mode $04 factory diagnostic commands out in TunerPro-RT (freeware).
Ever since I had to buy the software when replacing my IP last year, I decided to make this my (%*^&. This will be for 94-95 only unless I get an ODB2 truck to play with:
So far, I have working:
-STS lamp enable
-STS lamp disable
-TDCO Learn command
-Time Set command
-Override idle speed
-Clear ECM codes
-Clear TCM codes
-Exit Test mode
Teaser vid for STS lamp test:
-STS lamp enable
-STS lamp disable
-TDCO Learn command
-Time Set command
-Clear ECM codes
-Clear TCM codes
-Exit Test mode
