bowtiebutler956
Active Member
Well, I think the title says it all. I've been trying to dial in my new hopped up IP. I retarded the timing a little, turned up the fuel screw 1/4 turn, and was playing with different boost levels. I ran it a couple times at 30 psi peaks just to see if it made much difference. I didn't seem like it gained much that high, so I brought it down to a 25 psi peak. I had just finished making a WOT video, when I smelled coolant, but my temp gauge was still at 190. I'm now getting air in the cooling system! Not just a little either, a lot! I knew this might happen as I'm still running TTY bolts, but its still a bummer. I was getting ready to buy a new set of 285 75 16 tires for it, but not anymore. I really wanted those tires. So, it will be getting ARP studs, and Felpro +.010 gaskets. Hopefully the heads are still usable.
When my videos finish uploading to youtube, I'll post them. It didn't pick up alot more power, but it seems to have shaved almost a second off of my 0-80, before I started smelling coolant.
Matt
Matt
