1994ch
I think it is a broken spring, I can turn the spring with a fare amount of force. The others I can not budge.
Sounds like you found your "ticking" as if it's loose, then it dosen't have enough pressure to "push" the rocker/push rod back to the lifter thus creating a "click" when it hits.
It's an interference engine - Can't you just put that cyl at tdc and remove the spring? Seems like the valve can't go anywhere.
