I think the front of the pan gasket is a part of it.
I now have the entire truck up on jack stands.
Stopped at the lumber store and got two gallons of mineral spirits. From somewhere I had acquired a hazmat suit. Going to don on that suit, put on the big green gauntlet gloves that seems to be chemical proof, get on the creeper with a handful of rags and various scrub brushes and give this thing an undercarriage bath. Get it all dried off real niice with a couple of cans of brake and parts cleaner, then drop it back to the floor and give it another short test run. Lets see what drips reappear.
One thing about now as compared to pre sealing the rocker arm covers, oil no longer steadily drips under the truck. At least now it could be drove great distances with an occasional check on the oil level.
The PO had replaced the engine oil cooler pipes with some sort of a hydraulic hose.
Just to be safe I am going to replace those hoses and install a new oil cooler adapter gasket kit.
Probably do that before the great wipe down as there is a lot of oil hanging on those hoses.
As wet as the front of the pan is I am guessing that there might be a mist of oil coming from that area too.
I once did have to timing cover off of the engine and part of the process of replacing the timing chain and reinstalling the cover was to install a short piece of gasket at the front of the pan, and to use some sealer at the back edges of that gasket. That portion of the gasket may have gave out too.
If that is so, maybe start a thread on if anyone has raised up and blocked the engine, then, lowered the pan and replaced the entire pan gasket ?
Just trying to avoid having to pull the engine from this beast, at least for this crucial moment in the frame of time.
The wifey wants to go to the cabin and I do not want to have to borrow a truck again to make that journey.
Oh yes, I had previously purchased and installed the fluid dampener and also installed a new front cranking shaft seal at that time, so, that should not be one of the culprits.
A view of the oil cooler adapter and the front of the pan gasket.
