Hink
Overkill Is Underrated
What's everyone running for ring groove clearance (not gap) and why?
Hink and I were speaking before the post. My Hummer manual has same spec as that from NVW.
Now, it makes sense because newer AM General aka Hummer is using what they had on record. But if the ine source to military is off, all of it would be off.
Hink has a GM 1993 manual that had different spec.
@Hink please post the picture of that here.
Can anyone please post any literature they have on it?
As pointed out by WarWagon, there have been other misprints.
Anyone have all data maybe?
I have always grabbed whatever book was at hand. I don’t remember tolerances- never try to on purpose- I always read the spec like 5 times while building.
Finding which is right is good not just for a few of us rebuilding right now, but everyone the builds afterwards.
Anyone that is running a recent build might want to open and correct before catastrophic failure occurs...
And on that note- always write and keep your actual specs as you do it for future. Maybe you catch something that was a misprint or you find the magic bullet and want to repeat it.
Went and looked at factory optimizer rings real fast, top ring is keystone. Wife called and had to run out the door before i got to second ring. She is driving so i can type... should have brought piston wnd feeler gauges. She wouldn’t mind an oily piston on the fj cruiser dash, right?
Also, wonder if
A. gm had different land clearances than gep.
B. Could specifications have changed when gep took over even if lands are same size?
Does anyone have specs for optimizers?
Those are just gap numbers?
Here is the only reference I found to measure keystone rings and it's a single taper example.
http://mmc-autoelectric.org.ua/manuals/eur/asx/2013/11/html/M111300850275800ENG.HTM
Yup. No other ring specs in the book. No missing pages, I literally looked at every page number.
Went to look at what came on the optimizers pistons second ring. They are torsional style, and I could NOT fit a 0.0015”/0.038mm feeler gauge in there- all 8 pistons. I have to Dig to see if I have one thinner, but clearly tighter than the 95 book specs. But there is carbon on the rings from running, so i would need to soak them to clean it for proper measurements 5 tenthhousandths is mighty small and could be the carbon blocking it.
Out of my 98 fsmView attachment 55627
Wow! Yeah, see? That second groove is way bigger there.Out of my 98 fsmView attachment 55627
