Reference Material: Turbo/Wastegate System
knkreb
The Bus Driver is here!
Delaware
So where did your getty-up-and-go, go anyway?
The most famous part of the 6.5TD engine is the “TD.” That stands for Turbo Diesel. We all love the singing of that turbo under the hood. Some sing, some are of key, and some don’t sing at all. So, let’s dive into the common turbo issues.
One of the most common problems that comes around on these turbos are:
“I'm blowing black smoke”
“I don’t have much power anymore”
“My service engine light comes on”
So how does this macho piece of hardware work? Pretty simple actually. It is an exhaust-driven turbine motor driving a centrifugal air compressor. There are two “wheels” connected by a shaft. One wheel or turbine-fan is in the exhaust stream, the other wheel or compressor-fan is in the intake path. As the engine runs it pushes the exhaust gas out through the exhaust system. The turbine-fan wheel is driven by that exhaust gas. It in turn spins the compressor wheel. The compressor wheel pushes more air into the intake of the engine. More air, more fuel, more exhaust. More, more, more, which means more power “available” to be made. This increase of air is called boost.
What is a wastegate? The wastegate is a flapper-type valve that opens up on the exhaust turbine side of the turbo. This flapper will allow exhast gas to bypass and not spin the turbo as much. This will reduce boost pressure. This flapper remains closed under most conditions (idle, cruising, etc). It is designed to usually open up during high-load conditions, which causes high cylinder and exhaust heat.
So does more boost mean more power? Not really. It means that more power can be made. Boost is air. Air is cheap. If you want power, you have to pay for that at the pump. Power is fuel. More boost means you can burn more fuel. You can always dump in more fuel (to a point) but it won’t burn effectively until you have enough air to complete combustion.
So how much boost can I build? There seems to be ongoing discussion as to how much boost you can make. Some people like the idea of engine-splitting boost pressures, others like longevity. Which ever you prefer will be the answer to your question. The fine folks at GM have said the 12 is plenty. You can run higher levels, but you better do some reading, and have some cash ready too. That will be spent on modifications to the engine, or modifications to the engine after it’s failure. You can run more than 12 psig of boost without blowing it up. How long will you get away with this? That’s a variable not yet established, but the event is usually marked with exciting noises and other fanfare.
So why doesn’t my turbo work? There is are some common failing parts on these systems that will put your turbo on holiday. They would be:
°Wastegate solenoid
°Vacuum leaks
°Vacuum pump
Let’s go over some vocabulary here real quick: (For pictures go here)
Wastegate solenoid - This little piece of . . . Plastic, yeah, that's it.....plastic....is a small solenoid-valve that PCM pulses in order to regulate the vacuum supply to the wastegate actuator.
Wastegate actuator - this is the small gold canister on the side of your turbo that pulls the rod to the wastegate. It opens and closes the wg by vacuum on a diaphragm which creates thrust on the rod.
Wastegate - This is a flapper-valve on the exhaust turbine side of the turbo that allows exhaust gas to bypass the turbine fan, reducing boost pressure.
Compressor - That is the intake air side of the turbo. It pushes the air into the intake.
Spool-up - That is the spinning-up of your turbo.
More in depth coverage lies below in this post. .
So, with that covered, now we talk about what is going wrong with all this pieces and parts. When the turbo stops working, it is usually because the wastegate is open, or opening. The wastegate is used to regulate the amount of boost coming into the engine. Why, you ask? Well for some very simple reasons.
How do I check to see if I have wastegate problems? A quick test would be, at idle, see if the wastegate rod is pulled up into the actuator housing. If it is, that is a good start. Now, pull on the rod, and see if you are able to move it. Pulled in means there is vacuum. Suction is good, but how much? If you are able to move it, then you may not have sufficient vacuum to maintain boost.
To really test the system you should get a vacuum gauge to verify readings - with engine idling you should have 26"hg at the vacuum pump and 15"hg at the wastegate, but the above 'pull-test' will show if you're in the ball park.
The wastegate solenoid is the most common failing part in the whole system. Chances are if you have problems, this is it. Now, don’t just condemn it because it’s everyone else’s problem. Verify first that it is bad. How?
How do I determine if my Wastegate Solenoid is bad? You must see if there is vacuum before and after it. Locate the solenoid by tracing the vacuum line back from the wastegate actuator. You will need to determine if you have vacuum after the solenoid. You’re looking for about 15” of vacuum. Many refer to this a pressure. It’s not really pressure, but suction. Notice I did not say 15 psig, but 15”.
This little valve has three ports. Only two of which you hook vacuum lines to. One is the vacuum source (to the vacuum pump), the wastegate actuator, and vent. Vent, is not something you hook anything to. Why a vent? That is how it regulates the amount of vacuum going to the actuator. There is a little steel ball inside the valve that switches back and forth between vacuum and vent. Here lies the problem. That ball will rust. When it rusts, it won’t roll anymore, so your engine power no longer rocks. Thus, you ain’t rock’n’rollin’ anymore. When the ball doesn’t move, it will get stuck and not allow vacuum (usually) to the wastegate actuator, leaving it open all the time. This means a no-boost situation.
The solenoid can fail in a vareity of different ways. It can fail to provide no vacuum to the actuator. (most common) It fail to provide vacuum always (not as common, but possible), the coil could fail, or no power to the coil from the ECM. Sometimes the ball will “stick” causing erratic boost, where it will spike up and down.
Can you fix this? Yes, replace it. No repairs ever found really. You can “limp it along” by spraying something like WD40 into the port. This may help to free it up, but it won’t live forever.
Where can I get one? Usually it’s a dealer item. Local parts stores don’t seem to have this item for some reason. Check around, there are some on-line parts sources.
I have no vacuum before the solenoid? You should check to see if your vacuum pump is working. If you have no vacuum present before the solenoid, then you either have a bad vacuum pump, or a leak somewhere. Chances are if you have an EGR equipped engine, you’ll have EGR codes if you have no vacuum, because they are all vacuum driven.
Weak vacuum too will also cause problems. You should have around 26"hg of vacuum available at the pump.
Where is my vacuum pump? It is driven by the serpentine belt.
Don’t rule out vacuum leaks. If you have a leak, you maybe changing parts that work just fine.
I am blowing black smoke, does this mean I have a turbo issue? Sometimes it does, if you have gone through all of the above diagnostics, and everything is okay, then may need to check some other things.
Does my computer (ECM) indicate problems with my turbo? Yes, depending upon your year, will depend upon what codes you will get. There are two generations of computer, OBD-I, OBD-II. The first one can be checked with a paperclip. The second needs a code reader. 96+ vehicles have the second generation that needs the reader.
What if my vacuum pump is bad? Well, economically speaking, you’ll have to make the determination if you want to replace it, or go with a simple spring on your wastegate to regulate vacuum. Yes, you can eliminate the problematic vacuum system on your turbo if you would like. So, why doesn’t everyone do this? Well, there are some things you need to watch in doing this. Your computer regulates everything with the stock system. You eliminate that, you will have to take over being the “brains” of the engine in the boost department. DO NOT replace with the spring system unless you have a mechanical boost gauge to monitor the boost pressure. Aftermarket products are available for a turn-key spring system, or you may fabricate your own.
How do I know if the actuator is bad? Well, this is not as common a problem, but does happen. You can check this by providing vacuum to the wastegate actuator, and see if it holds. If it leaks, then you may either replace the actuator, or go with the spring/mechanical system.
What happens if I build too much boost? Then, that’s called over boost. This is where the computer takes evasive action to prevent from blowing up. Depending upon what your computer is programmed to do, it will either dump the boost, or go into limp mode (may limit engine to 2000 rpm, and no power) This will also set the Service Engine Light.
So I can have either too much, or too little boost? Yes you can. Either is undesirable. Too little will not provide complete combustion, and cause higher EGT (Exhaust Gas Temperatures). Too much boost will cause unnecessary stress on the engine.
Are there any other things that will effect this system? Yes, the air filter. If it is dirty, it will reduce the amount of air that the engine can ingest. This can make noticable engine power losses. Don't trust that little pop-up thingy to tell you when it's dirty. Open the filter box up and check for yourself.
Does the turbo work all the time? Yes it does, mostly. At idle, under load, etc, it's spinning, or supposed to at least. The wastegate opens to bypass some of the exhaust gas to reduce boost under high-load situations. There is no occurance where the turbo "shuts off" under normal conditions or at idle. It will always be spinning.
What are the drawbacks to this turbo system? Well, it performs well under the conditions it was designed for. If you begin to take it outside of those operating parameters, it becomes an expensive hairdryer. Turbo compressors produce heat.
What's wrong with heated air coming out of the turbo? Well, the heat makes the air less dense. You are wanting more density of air to burn more fuel. That's what a turbo is for. It's for jammin' more air into the intake. Once you heat the air, it becomes less dense, and starts to be counter-productive.
How can I overcome this? You must come up with some method of intercooling. That is a way of cooling the air charge before it enters the intake. Under high boost conditions, your intake air temperatures can rise to 200°+F. That's the INTAKE, not what's happening in the exhaust, or the clyinder, that's BEFORE it gets there.
How can I intercool my engine? There are intercoolers available on the market that uses air to cool the air charge. There is also water mist injection.
Do I need an intercooler if I don't do any towing or have any performance modifications? Well, it's up to you. The current stock setup will get pretty hot still. It's all in where you want to spend your money. Do some more reading on the subject and see if this is something that suits you and your budget. Of course we'd all like to have our engines as souped up as possible, but then again, we have other payments that are calling our names. . .
How can I put an intercooler in, and how does it fit? Do a search, there are many others.
Hope this helps to you to better understand everybody’s favorite part of their engine: The turbo.
Going further with this troubleshooting, the WG canister on the side of the turbo has a diaphragm inside of it that over time can develop a leak, and at idle appears to be functioning properly, with the WG lever rod fully engaged into the diphragm housing, but when truck is at power the exh flow can ovecome the ability of the leaking diaphragm to keep the WG flapper closed.
To test it a Mitey vac tester vac is applied to the WG actuator with vac line disconnectd, actuator should pull in and hold shut. It only takes a little lost vacuum to allow the WGs flapper to unseat and boost falls off. Same mitey vac can be used to test for the lines leaking, unplug main line from the vac pump, then remove from the solenoid/s and plug the line vac should hold with the mitey vac pulling vac on it.
To dynamic test the system as a whole to make sure vac pump is good, tee into the line that feeds the 1st solenoid in the bank of 3 solenoids if you have a L56 "S" vin EGR setup, or the inlet of the 1 solenoid for the L65 "F" non EGR'd trucks, snake into the cab from under hood a length of vacuum line (be careful not to pinch it) to a vac gauge in cab, & go for a drive, vac should remain 20+" Hg.
If vac holds good with that, then start working with same setup in cab but reconnect the tee to the outlet of each solenoid to know if it is cycling like it should, replace the one that isn't funtioning properly.
"Can you add anything about the path of oil that runs thru the turbo.......Trouble spots, common leaks and so on? "
X2 ....
Pretty basic oil comes in from pressure feed at top, through the feed hole for the sleeve bearing, and gravity drains out the bottom, seal failures are uncommon, oil found inlet of the turbo 99% of time is result of vapor extraction via CDR either bad CDR valve on valve cover or excess blow-by being scavenged, there is one other I've seen via turbo where a bad head gasket was allowing crank-case to fill with water and oil was being scavenged via turbo with solid black stream down side of the truck, Ain't that right Justin :)
Hi Tim,
Can no Oil be in the Intake Side of the Turbo at all?
Last year I had changed the CDR (there was also a part of SS Diesel) and I have still, just like before Oil in my Intake!
Greeting
Gunar
Gunar, unless your engine is new and tight there will be some oil in the turbo inlet.
Gunar, the older and more worn out the engine is, there will be more blowby, which will give more oil in the turbo inlet.
Leo,
Engine is new...some Oil...Engine have many Miles....no Oil..?!
Sorry...i dont understand this....
Gunar
Rings need seating on a new/rebuild engine,can take anywere from 10000 to 20000 km depending how you break it in,check oil level daily.
Engine with many miles and properly broke in should not use oil...well,not much anyway,
If it does start use oil(not leaking),vent the CDR to the world,problem solved.(my fix)
The GMCTD post of how the Turbo/Wastegate system works:
EFI Turbocharger Wastegate control is part of a true Digital Vacuum Regulator, managed by PCM.
The turbocharger is an exhaust-gas driven turbine motor that powers a centrifugal fan which compresses intake air, making Boost pressure - a Wastegate in the turbine housing is used to bypass exhaust gas in order to regulate that pressure for safe engine operation
The Turbine Wastegate is controlled by a DIGITALLY REGULATED vacuum system consisting of the Manifold Air Pressure sensor (Boost sensor), the Vacuum Pump, the pulse-width modulated Wastegate Solenoid Valve, and the Vacuum-operated Wastegate servo-actuator, that round cannister on the side of the turbocharger.
PCM controls vacuum to Wastegate via pulses to the Wastegate Solenoid coil, by varying the width of the pulses, termed Duty Cycle - wide pulses open valve against spring pressure, narrow pulses allows spring to close valve.
Wastegate Solenoid consists of a three-port spring-loaded armature-driven valve, with a port to Wastegate Vacuum Servo cannister, a port to the Vacuum Source and a vent-port to Atmosphere.
When valve is closed, solenoid off, vacuum source is blocked off, and Wastegate port is vented to atmosphere - permits some actuating vacuum in Wastegate Vacuum Servo cannister to bleed off, allowing Exhaust Pressure to pass thru Wastegate into the exhaust elbow, bypassing the Turbine Blades.
Valve open ports vacuum to Wastegate Servo, restricting vent, but not closing it - this allows REGULATION of vacuum applied to Servo.
Wide pulses keep Solenoid valve open to vacuum source, narrow pulses allow spring to close valve.
Vacuum applied to Wastegate Servo forces Wastegate closed against Exhaust Pressure on Wastegate flapper valve.
Exhaust Pressure increases with RPM and heat, created as result of Fuel Combustion - as Exhaust Pressure increases servo vacuum must be regulated to maintain factory determined Boost levels, usually 7-8psi max without cooling and exhaust modifications, and without reduction of Charge-air temperatures via some form of heat exchange.
With 67% Duty Cycle to WG Solenoid at idle, any rising exhaust pressure immediately 'spools up' - increases rpm - the turbine blades, shaft, and compressor fan, creating instant Boost, which rises further as exhaust energy - pressure, volume, and velocity - increases.
As PCM senses rising Boost pressure via MAP sensor in intake plenum, Wastegate Duty Cycle is reduced as required to vent vacuum and maintain correct Boost levels.
MAP sensor signal - on pin B - to PCM varies from 0 volts at 0 psiA to ~2.4 volts at 15psiA, to ~5 volts at full Boost.
Note the unusual pressure figures in that statement - they are in Pounds Per Square Inch ACTUAL, which is based from ZERO Atmospheric Pressure = 0hg on the Barometer Column scale.
Since Vacuum is terminology for measurement of pressure less than Atmospheric, where ZERO Vacuum would be 15psia or 30"hg, Zero Baro would be (-)30" on the Vacuum scale
PCM calculations are based on 0 psia - MAP sensor is calibrated to 0 psia, such that it's output is actual Atmospheric pressure at ~15psia.
Boost Pressure is based from 15psia Atmospheric - 30" Barometric - where 15psig Boost would be 30psiA.
As PCM sees increasing voltage from MAP pin B, indicating increasing pressure,Wastegate Duty Cycle is reduced accordingly, reducing Vacuum to Servo, venting Exhaust Pressure around Turbine Blades, regulating Boost.
As PCM sees decreasing voltage from MAP pin B, indicating decreasing pressure, Wastegate Duty Cycle is increased - a true DIGITAL VACUUM REGULATOR .
Because Vacuum on the Wastegate Servo is infinitely variable, Wastegate does not simply 'blow open' to dump Boost, but is 'metered' to allow just enough exhaust gas to bypass turbine such that Boost level is maintained without wild swings, or reduced when necessary.
This is easily observable when a Boost Gage is installed - PCM may allow stock Boost to spike on sudden accel, but recovery is even and smooth, down to 7-8psia factory limit.
Digital Vacuum Regulation is used in EGR system, where equipped, also.
Voltage readings for testing -
PCM bases all pressure readings on actual pressure of 0 pounds per square inch, or psia, tho some call this pounds per square inch atmospheric
Since the Manifold Air Pressure sensor is calibrated for 0volts, repesenting Zero Pressure, to 5volts, representing some higher pressure, it's output is approx 2.4volts at Atmospheric pressure, or ~15psia Barometric pressure.
2.4volts is approx half of 5volts, so we would assume the max MAP output, at 5volts, would be a little above 30psia: 15psia Baro + 15psi Boost = 30psia.
PCM uses these voltages at the pressure input to control vacuum on the wastegate, regulating Boost pressure
The "S" engine, with EGR, uses a MAP sensor for Boost, with a separate pressure sensor on the firewall to measure Barometeric pressure and vacuum for EGR operation - the "F" engine has only the MAP sensor, using it to measure Baro pressure during Wait to Start, then measuring Boost when the engine is running - identical in appearance, their calibrated outputs are different and specific to the separate purposes, so cannot be interchanged for testing
Critical tool for WG troubleshooting is a vac gauge, also handy when trouble shooting a lift pumps output when under loaded condtitions, with a tee in line of the WG solenoids output to the turbo vac can you can run an extended hose into the cab and watch vac as it is modulated to the WG actuator, be careful to not pinch off the vac line as you run into the cab and "dead head " the reading.
Remember the way the WG works is inverse of what you think it should, vac should be fully present to keep the WG actuator closed, then as you start making more boost than is required by the PCM the vac signal is vented so less drive gas goes to the turbine section lessening boost produced by the turbos compressor.
Attached is a vac diagram of the OBD-II (S) L-56 engine wich is similar to the F engines except they do not have the EGR supply & vent solenoids.
One last item when having intermittent boosting issues I found on one of mine once a problem with a small hole in the WG actuator/cans diaphragm which would allow vac to appear as if acting normally and even passed basic check but under load of higher engine operations & exhaust flow there was insufficient vac to keep the WG actuator fully closed and basically de-boosting the turbo and throwing a WG fault code.
I temporarily wired shut the WG to confirm the suspicion then used my Mitey vac to see if the canister was having issues, it was.
I know that this is an old thread so pardon me for throwing in here.
if I need to start a new thread then please advise me and I will do so.
The turbo boost on My 2000 K3500 is setting a code, P0236, Turbo charger boost sensor A Range Performance.
I have visually inspected all of the vacuum tube/hoses and with two vacuum gauges Td into the system have verified that I am not loosing vacuum through the systems.
Running with a volt meter Td into the boost sensor, both reference and signal wires and everything for voltages seems to be working properly.
I pulled he wig plugs and with a ha he bead blaster, My best to clean the terminals. It took a lot longer after the cleaning for it to set the code but it eventuall came back.
What would be the sensor A range, I guess would be the question.
To remedy this for now, I made up a bracket from some scrap items laying around and made a manual waste gate controller with destroying the good waste gate actuator.
Start a new thread. This is reference material. Do you have a boost gauge and see it's in range. Factory turbo should spool quick under load and run 4-8 psi boost running down interstate depending on hills/load Your home made turbo master (spring mechanism) should work fine it should have boost. But should make sure it does not exceed 11-12 psi for a little while or will give code if stock program. If boost stays between 1-2 <10 psi might be a bad map sensor. Sorry I don't know corresponding voltage range for map sensor.
I`ll do that. thank You.
