matuva
Tropical 6.5er
Well, I finally made my decision:
Rather than guessing what is causing my oil consumption throughthis massive oil leak through the turbo (stem seals, broken ring, yada yada....) I choose to rebuild an engine.
My fater in law (and mechanic) is offering me a used 141. This engine was running good, but a :tapedshut: guy found funny to poor some sand in the oil filler. Wonder why we get so much play in the cranck while rotating it....
So, I will:
Will dress it yellow cat with black intake and T-stat housing.
Anything else I should think about the rebuild process?
So, I will:
- replace cranck
- replace all rod, main, cam bearings
- replace all rings
- replace all seals on valves, especially the postive stem ones
- of course all gaskets
- new timing set
