Seal puller cakewalk however: It's very tricky to make sure the TC lines up and slips in to turn the pump. Thus you mark the depth it is at and it's o'clock position before removal. Then you make sure it goes back in to the same depth by turning it after slipping it back in at the o'clock position it came out at. If it isn't at the same depth it's not right and will do expensive and quick damage.
You have several sets of splines to line up and the pump drive thus the trick to it.
I think there is two sets of splines and then two flats on the outside of the TC sleeve.
If it does have those two flat spots, those are the toughest to get to align.
With any pressure on the front pump, it too will turn as You turn the TC to get those two flats aligned.
IIRC, there should be three clunks as the two splines align and then the two flats.
Maybe someone correct me if My IIRC is not RC. Meaning remembered correctly.
That is why it is a good idea to follow what WW has posted above.
When the TC is setting correctly, it is like one of those aaaahhhh moments.
After getting the TC properly set into the splines and flats and knowing it is correctly aligned, I like to use some mechanics wire and run the mechanics wire through two bell housing bolt holes to keep the TC in position, then, after getting the engine, or transmission, close to alignment, pull the wire.
