Dye is always uv dye, and unless it's a big leak, you will most likely need a black light and want a pair of the yellow lense glasses to make the dye stand out. Common leak points for the a/c system are low pressure switches on the accumulator, if it's a 96-02 it most likely has an R6 delphi compressor, aka THE BELLY LEAKER because they leak and drip out the bottom from the end cap seals, and the other BIG leak point is that ridiculous high side schrader with a rubber flap valve in it right where it gets blasted with super hot refrigerant gas leaving the compressor. The aftermarket now makes one that uses a regular screw in scrader valve inside of an adapter. Bought a couple at o reillys last year for $6 iirc. The easiest way to check the scraders is with the system off(but charged with some pressure), put a dab of a/c oil in them, then watch for bubbling.
