Possible Engine Build for my 93 Truck
The way the seal is showing in your picture is the way it should be installed upon the engine block and main cap with the front of the engine facing the arrow direction.
Plastigauge... do I need to clean the oil off the bearings and crank before using? I assume it's a wax compound, brake cleaner to get it off once used? I need to look up a video on how it's used.
