ghost183
need opinions and confirmation here fellas
heres the deal....
when i bought the truck, it had a replacement PMD mounted on a SSD cooler on the intake due to the original failing, its still mounted on the ip for christ sake... truck ran great!! powerful, instant starts.. all was good but i had surging when hot, when ide apply thottle in reverse ( no surging if i let it move on idle in reverse), so, as directed from you informative gents here, i relocated the PMD and cooler to the bumper hole, NO more surging, BUT, i later found out that the pmd isnt waterproof, duh..
rarely, i mean rarely, i would feel a loss of power, intermitant and usually lasted about 3-5 secs, before and after relocation of the pmd...
then i had that major WIF issue (what a nightmare, thanks you guys for all your help) those infamous 251 and 370 codes being repeated a bazillion times.. sheeez
and follow up rattling issue ( another nightmare, and again, thanks are in order for all your help and guidance) remember that one? engine/trans seperation?!?!?!
now... 1/30/09, keep in mind.. NO CODES
i get random stalling.. i coast to the side, and it starts back up within a few secs, only happens when hot and idling for a long time
ive noticed the engine is somewhat tingier, aside from the compression knock, i hear tinging of some kind, so i stethescoped each injector, and found #5 & #8 injectors sound weak, their clicking is faint and not as authoritive as the rest
for the past few days i watched for, and now confirmed a lose of power
also, its start up was usually instant, even in 8 degree weather, -15 with the windchill, instant, but starting up this past week, it kinda hunts and then starts, it sounds as if some cylinders fire right away (like they usuall do) and some are following along for a few secs, alond with a very minimal puff of black smoke, not gray, black
yesterday driving on the NJT, just cruising along, no rush, mainly due to these issues, about 2k rpm, i got a power spike, lasted for about a sec, and it was very noticeable cause the truck had the power it used to have before this power loss issue
and all this with NO SMOKE, i used to get a nice black trail behind me under power on the highway, now.. nothing.. no smoke.. and no power to boot
now.. during all this, these past few daysduring all this testing, its been wet here, rain, snow, lowsy weather.. engine temp is at 170-180 as usual, oil pressure is as before all this
so...
whats going on here? im assuming pmd? or is it those 2 injectors going?
some one point me in the right direction... both my vehicles went down at the same time so im hurting here, sheared my pinion bearing in my other truck and blew the R&P.. so cash is tight.. and i mean tight
anyone local, or somewhat, to brooklyn. ny, who wouldnt mind swapping pmd's with me for a test?
and oh.. just thought ide mention the LP was installed NEW about 7k miles ago
heres the deal....
so...
