Peoria plaza tire
Jaryd
Extremely Deplorable
Hodges, SC
I would call the lift kit manufacturer to get torque specs on their stuff and get a service manual for whatever vehicle your working on for the torque specs on that end of it.
Might could google the specs for the vehicle but probably not the lift kit.
BoostN
Staff member
Administrator
Tennessee
Each lift kit manufacture should have that information available. Welcome to the site!
Will L.
Boulder City Nv
Alldata is the probably most common source for multiple vehicle specs. It's normal for any mechanic shop to have access and computer for the techs to use. Before the magic of computers, shops like my Truck equipment shop had Thousands of dollars invested in paper manuals.
But it is crucial to use the instructions from manufactures. I remember Bell Tech drop spindles used to require a different fastener than the stock one and torque spec was much higher. Lean on your suppliers to get you proper specs in writing- your liability needs to be covered. When we would do one off builds for DOD, DOJ, DOT, etc we had to have stamped engineering plans for them. At one point we installed Timbren over load springs on around 100 mail trucks and the required paperwork jacked the price up to nearly double. Err on the side of caution.
btfarm
335,000 Worth and counting
Staff member
Lead Moderator
Sandwich, Illinois
As a retired mechanical design engineer, I have several charts available with SAE (and others) recommended torque specs per fastener sizes, grades, and types, but in your case, and as Will said, you need to go with manufacturer data for liability and safety reasons.
Welcome To the Truck Stop!
