After consulting with heath diesel about all topics covered in this thread, this is what I've decided on : I am in no way saying this is what Heath diesel said - Just after conversing with Bill for about a half hour and listening to his experience with things, I've settled here. thanks for all suggestions and i hope to document information for others from now on.
Head studs
hurricane 7 center section
ht4 camshaft
stock bosch injectors
updated heath tune
Griffin Radiator
Leroy crank pulley
fluidampr
frc10
pre filter, new water separator
upgraded oil filtering - not sure what yet, most likely centrifuge and larger capacity filter.
Leaving stock chain / timing setup - chains run less resistance then gears most times, the chain is also designed to never wear from the way it was produced as far as slop or slack goes, Call heath and ask them about these parts. it was interesting information to learn
not using gapless rings - not a believer, ill leave it at that
Rocker arms - Not needed,
Head studs
ht4 camshaft
updated heath tune
Griffin Radiator
Leroy crank pulley
fluidampr
frc10
