iamdave0887
Here Comes Chaos.....
took off from a stop sign today and the truck seemed to cough and sputter. SES light kicks on and i happened to have my code reader with me. pulled over and checked it, i had P0251, P0070(wtf?), and i believe the last one was P0370(but i can't remember). i know the P0251 is a code you really never want to see, but i cleared the codes and kept driving. The truck had all its normal power, no black smoke, and sounded like it always has. i get up on the highway on ramp about 1/2 an hour later with a friend of mine to go pick up some parts for a repair job. I step on it and hit ~70 mph and my buddy looks over at me and says "it feels like your truck is stumbling". no sooner did he get the last word out of his mouth, the truck shook violently once(felt like someone rear ended me) and kicked an SES. check it again, P0251. :cuss: :cuss: :mad2:
i called Bill Heath to ask his opinion before i started donating organs to afford an IP. he said that the P0251 and the other associated code(which i cannot remember the number now but i think it was P0730) is a sign of a weak LP. last i checked my LP pressures i had ~4.5 psi at idle and ~1 psi WOT with the stock programming. Bill said it should be ~7 psi idle and no less than 2 psi running WOT with the GL4 reflash.
now that the story is told, my questions are 1.) how much debt am i going to be in now? 2.) What do you all think? and 3.) anyone got a fuel pressure gauge thats local to me? i can't find my fuel pressure gauge anywhere. i did check for flow and i opened the t-valve with the engine running and a hose attached to the drain valve and i did get fuel out of it and the truck didn't stall out. it didn't seem like that much fuel however. It looked more like a gravity feed trickle then anything with pressure behind it.
