Need to check with Bill and find out why you are getting it, P0236 the code you are getting ???
Well, the question is, what is the boost when it is setting the code? Is it actually underboosting. If you are already going a good speed the ATT doesnt just quick go to 14psi on the highway unless you are under load. Although Heath may have tuned for it to be 14psi under those conditions, but the ATT is only doing 7psi. So you code for underboost not overboost. And its a 10 second condition to code.
They could have just disabled that code all together, but they make the tolerances higher so it shouldnt set in most case if using a TurboMaster and GMx turbo. The ATT doesnt boost the same way though.
