Oil pressure sender
Use the 6.5 switched sender, just clip the wire(s) for the switch.
Even if the switch side fails, the sender side will continue on in its duties. 🤷‍♂️😹
The reason the newer ones burn out more frequently is the excessive load from the lift pump on it. Adding a relay eliminates the problem. If you are just using it for the pressure- it will last a really long time. Being smaller and more readily available- Just stick with it imo.
if you need OP sensor only....you must go over aftermarket spare part sensor
this is my part spare for fuel pressure sensor
it has stainless steel housing .... you can choise bolt tread, pressure range or Ohm range
whatever you need, it doesn't cost a fortune
when bought it, 3-4 years ago about $18/20 from china
you must measure your old oil pressure sender if it is in good shape....
but if you don't know how to measure Ohm ... I think it's better for you get help from someone. also to not short the sensor when you connect it.
OIL PRESSURE GAGE
The engine oil pressure is displayed by the Oil
Pressure Gage. The pointer of the Gage is moved by two
coils, and its operation is similar to that of the Fuel Gage.
The Oil Pressure Sender is connected to the junction of
the two coils. It has low resistance when the oil pressure is
low, and high ohms resistance when the oil pressure is
high. This changing resistance changes the current flow
through the coils. The magnetic fields of the coils move the
pointer from low to high.
connect the sensor to an air compressor, low pressure line with pressure tap and gauge and increase the pressure da 0 psi to 80psi meanwhile you measure with a multimeter the output signal from sender to gauge ....use a battery to power the sensor, it has 3 wire positive inlet, positive outlet, and signal to the gauge, negative pole is the sensor mass...
see pdf Attachment
  • ops-chart.pdf
