I'm now setting at the computer where I can type instead of playing around with the phone. So I'm going to restate what has occurred to now.
Last Monday when it was 0F outside the glows worked fine and truck started without being plugged in. At the time this happened it was in the mid-upper 40's that night, mid 30's the next morning and low 50's today.
Was driving at interstate speed for 4 hours. Pulled into a truckstop to sleep. It was raining so I parked close to the building to use the facilities. When I came out (5-10 min outside temps mid to upper 40s) and started the truck it started immediately and ran long enough to back a truck length out of the space. Then it cut off and would not restart.
I attempted to restart until I thought I had 1 more attempt to start. I decided to let the truck roll out of the way and try the last attempt in daylight, when hopefully it wasn't raining, and I could move the PMD from behind the bumper to the pump and make sure the cable hadn't gone bad. No change with PMD at pump. At best during all of this cranking I got a slight fire out of maybe 1 cylinder. Had a service truck come out and continued to attempt starting hooked with cables. Good starter speed. Borrowed a 3/4 wrench and cracked a couple injector lines, had a little fuel come out. They had a mechanic who was familiar with the 6.5 but he wouldn't be able to work on it unitl tomorrow.
Get truck towed back to house.
Hooked new Stanadyne PMD direct to pump. No Change.
With charger on batteries, run direct power line to lift pump. Fuel comes out bleeder on filter manager. Fuel comes out of the T-drain at the rate of ~16oz in 40 sec.
Cranked and got fuel signs at the injectors.
Installed clear line in injector return line, have no bubbles visible in line. After ~24 crank attempts (point batteries started to need charge) only got about 3 inches of fuel in return line.
After bleeding lines cranking resulted in an occasional week attempt for a cylinder to fire. Very slight amount of black smoke produced at exhaust, not enough to see from drivers seat had to have someone watch.
Tomorrow I'll try to dig up my fuel pressure gauge and check the fuel pressure.
Pull codes, I"d been getting some intermittent check engine lights. Previous owner had installed a Humvee intake and removed EGM, disconnected Baro sensor, and something else I think. Wish my brick wasn't dead.
