fbh31118
Cadet
Well my turn has come to diagnoise my A/C. The compressor is not even turning now so if it's similar to my 95 it must be either low on freon or a failed presser switch or something that I can't afford.
1 Is the low pressure switch the one right behind the compressor?
2 The compressor turned as soon as last week so I'm pretty sure it's ok so would it be safe to jump out the low pressure switch and add the correct amount of fluid if its low?
3 Is there a shreader valve behind the pressure switch?
4 Are there any off the shelf freon bombs that you would recommend as good or bad, with the gage for instance, with or without stop leak?
Thanks for any help.
