Chevypoor
Active Member
Been looking for a reg cab 4x4 5spd for awhile. Found a couple but they were either too far away or at the time the money was an issue. Initially the search was for a 94-95 truck. After Larry and Gertie's electrical/ tuning gremlins I have been looking for a 92-93 rig. Located one a couple of weeks ago and today we drove out to Ferrum Va to pick it up. The PO stated it had a minor head gasket issue but was otherwise in great shape. Stated it was totally driveable. Started up great- it was a cold start. No smoke on start up and no white smoke. All fluids looked ok and at proper level including the oil. After a brief test drive I was sold. Runs like no 6.5 I have driven and it appears to be all stock- it just flat halls!!! It drove fantastic on the way home. Temps stayed two bars below 210 the whole 3hr 180 mile drive. It has more power than Gertie with all the mods, pulled the mtns great. Left my wife in the dust and she was driving the new 2014 6.0l gasser! Cruise works, power windows and locks work as well. It does blow bubbles in the rad and after a 3hr drive the overflow which was empty at the start was 2/3s full. Top hose is firm and when you shut her down you can hear it gurgling. Clutch is super firm and she shifts nice. Appears to the original block and turbo. After the drive home she puffed once out the fill cap and then no blow by. PO brought the truckfrom Oregon and has 100% zero rust. She has 294k on the clock and runs like a swiss watch. The IP is recent from Oregon Fuel Injection (20-25k on the pump) and it looks like they did a timing chain when they did the pump. Plans are to remove parts from Gertie and sell Gertie with no motor. Going to fix the head gaskets and while she is apart install the ATT and a few other mods as well. Here is a pic! Will post more pics tomorrow!
http://s1358.photobucket.com/user/T...906_164529201_zpsfbe8dade.jpg.html?sort=3&o=2
