Mudbath
Old Smoky
This started yesterday at 120 kph and slowly got worse, it is in the drive train and interesting enough blows the 30 amp aux B fuse in the under the hood fuse box. When the fuse is blow the brakes act very strange and effect the ABS. I replaced the fuse and all was fine, until I got to highway speeds again and the vibration occurred, when stopping the brakes were whacked again (blew the fuse again). The ABS light does not light indicating a problem and the paper clip OBD1 method shows no code. I am not sure this method will show ABS codes though. Does any one know for sure? If not, does GMTDScan Tech show ABS codes?? I am going to have a look at the front hub/speed sensor assembly. It is almost like something is worn there and maybe something is hitting the speed sensor and causing the fuse to blow. I will be in in a hour or so to check emails so if you have any great ideas I'm all ears. Thanks Bob
