Glad to have been able to assist Todd,
For "Rest of the Story" I've been working 10-16 hrs a day last couple of months 94 hours last week I'm a little whupped up after last week.
Todd managed to get up with me at break times and we did some over the phone diagnostics, He's getting very good at pulling the intake now, 1st to remove for IP, 2nd to remove for pinched wires, and 3rd time a charm to replace the OPS.
After describing the work to complete the IP swap and no start, I suggested jumpering the test lead of the lift pump to the 12V aux terminal to make sure IP/fuel filter mgr was fully primed, he called back "the big 30A aux fuse blew"......No way says I.
Hmnnnnn....... that wasn't doing that before and jumpering to the aux terminal should not pop the fuse unless........ Did you possibly pinch a wire when intake was off then back on ????
Yup the OPS wires, removed intake fixed those, replaced PCM fuses, truck starts/runs but no oil pressure indicated......."That's not good says I", (1 of 2 things) the dash meter blew or the tiny wires in the OPS itself blew due the direct short to gnd.
The latter was the culprit new OPS corrected the issue, he only has to re-time it now.
With regard to OPS removal any OBD-II guys know of a better way than removing the intake to get the OPS off the engine, Todd could only get to it with an OPS socket with intake off, which is only way I've removed them when I do IP swaps I replace the OPS as a preventative maintenance action since I'm already there.
