I had the pump off because I initially planed on using the other block. But then changed my mind and used this 599 block. I did mark it but I didn't get it back on perfect so now I need to do the relearn. I am having a heck of a time finding someone with gmtech 2. I found a scanner with it online for around $300 but just can't afford that right now. I can't wait to see how she moves once it is set properly. It goes pretty good right now. I am loving picking my own gears and the feeling of a direct link between my rear tires and engine.
I don't think air matters in the injector return lines, just if you see it at the IP, then that's bad.
I will be about 4 hours from you in less than 30 days
OK so today I towed for the first time with my manual transmission. I was very happy at first. The thing pulled like a train. Would run smooth and quite at 75 mph with what seemed to be 1,000,000 HP. Then I hit some mountain passes and very long very steep grades that brought my truck to its knees. It got very hot twice around 235 ECT and once up to about 250 ECT. EGTS only hit 1150 once though.View attachment 44208 View attachment 44211 OK so today I towed for the first time with my manual transmission. . . . Then I hit some mountain passes and very long very steep grades . . .
So my biggest complaint is my WIDE ratio transmission. If I am starting out on any grade I have too run third gear all the way to the red line before I can shift. Even then I hit 4th at a boggy 2200 rpm. There is a 1200 rpm gap between 3rd and 4th and that is the hardest thing to overcome when towing. I loose boost and billow smoke, then EGTS spike and ECTS follow.
This only causes me problems on the toughest of hills. Over all I am extremely happy with this current set up.
You have an issue if you have 195 thermostats and it never gets over 170 on a decently long drive.Good set of details!
Getting less sold on the 5 speed for just those reasons. Time to dust-off finding a 6 speed solution.
For the cooling issues, am with WW. Previous winter with an OE setup and 190* F thermostats, ECT's (as reported by the ECM) were ~180F. This winter with a DMax fan, new fan clutch, and 195* F thermostats, ECM rarely shows over 170* F in the same conditions. Only other difference in configurations is that am currently running Evans coolant and I replaced the water pump for a new spin-on. Well, Ok, there is one more difference in that the previous configuration was a 599 block and now I have a P-400; not sure that this plays into the cooling, but just want to mention all the variables.
