I'm new and hate to start out with a long post. I came out from work a couple of weeks ago and noticed a puddle of oil under my van, was pooring out of the oil filter. I removed it drained it put it back on and added oil and it seemed to work but still replaced with a new one. The next day coming home I noticed my battery was dying, replaced the battery but started doing the same thing so I removed the starter and alt. and had them tested, both were bad so I replaced them. I figured that sense cold weather was coming and I was replacing things that I would also replace the stater relay on the fender, glow plug relay and the relay next to that one along with the fuel filter and belt. Now comes the major problem I have to turn the key 4 to 5 times to get it to start and it will finally start but only run for about 30 seconds and then it cuts off and I have to repete the process and it dies again after about 30 seconds. I pulled the valve cover on the pasenger side because I noticed that this side was not getting warm after it ran for only 30 seconds, only the drivers side was getting warm, connection was ok. I'm thinking that I wired something wrong. PS: all fuses in the interior and exterior boxes are good. Please help, thanks
