DieselAmateur
You could theoretically mount a temp sensor in either the fill or drain plugs. Just take either plug to a decent hardware store that has a way to identify threads and find a plug that can be drilled/ tapped or is already threaded for 1/8" npt as that's the common trans temp probe size
I run the Tribodyn 75-90 gear oil in my front and rear diffs and in the final drives on my mini excavator. Pricey compared to standard off the shelf stuff but when compared side by side after draining my final drive motors the Tribodyn looked exactly the same as when it went in and the grey mobil gear oil was diesel black.
