preachermic
I've read and read and I can't figure this out. My timing is desired 9.5 and actual 9.5 with the TDC offset at -2.02. What do I do? I am getting a TDC offset error. I am also getting a code 83: TCC Solenoid.(related or not?)
I'm running MaxETork also - the chip cannot vary the basic timing specs derived from mechanical IP position relative to crankshaft position - only the owner\hacker and timingtrain wear can do that - only the fuel rate curves within the timing specs can be adjusted with software, plus maybe the DESIRED timing within those specs - but never the MEASURED timing - I would doubt whether the TDCO relationship has been altered, also, as that is based on the camring ramping factor.
