schulte
ACCELLERANT!!!
Got an ugly bearing noise coming out of my motor. Can't tell if it's inside the motor or off the serpentine belt.
Sounds like your typical bearings about to grenade sound; like a glass jar of BB's being shaken.
It's intermittent; it comes and goes at idle, but is more common when the engine is up to temp.
Just replaced the alternator; almost 160k on the clock and the factory one finally gave up... thought this might've been it but I guess not. While replacing, I spun both idlers and the tensioner pulley, found no excessive play or noise from being spun by hand.
What else could this be? I'm leaning towards the PS pump, but I'm hoping that's not it. I do have the truck leveled out with 35's, so it would make sense cuz the PS takes a real beating.
Could this be something more serious, a crank bearing? It doesn't sound like one to me, but from where it's coming from it seems like its IN the motor. I wouldn't think a main would be bad this early... oil's always been full and changed on time.
