cub124
Half Moon Detroit #1
As some of you may know I have started the nv4500 swap in my 82 k20, anyhow I switched to a hydro clutch and a 93 6.5 clutch. The clutch petal has full master cylinder depression, a new clutch line ran and a new slave cylinder. I have bled all the air out and was having problems getting the fork to move (trans is still out until the clutch is in working order) so I pulled back on the fork as far as I could which depressed the slave cyl. and the hydraulics started to work a little bit. I suspect the problem is the bran new slave cyl but Im not sure....this is why I wasn't looking forward to a hydro clutch :mad2:
