05lly2500hd
Recruit
- Messages
- 67
- Reaction score
- 0
have you checked the ficm fuse. it is num 25 under hood. also there is 3 grounds on the lower right side of the engine block. triple check those. for the ficm. and ecm.
will double check the ficm fuse, I do have 3 grounds on each side of block.
2 in same harness as cam/crank sensor, one in same harness as starter "switchleg, and then on driver's side, the main from battery, one to starter and one in oil level harness. One from head to firewall and one from firewall to hood.
