kane
:confused5:
Around half a year ago... everything was ok. I had peak 0.7bar and WOT 0.5bar with stock chip and after replacing EM chip, peak was 1.0 and WOT 0.8bar...
Now I can't figure out what changed...? I get only 0.5-0.7 at WOT and the turbo meter needle does small up/down WOT. If I close wastegate manually... same boost. Nothing more at all... Even with stock chip I get 0.4 WOT... no 0.7 peak...
I've checked intake, no leaks at all, fuel pump ok and pressure seems ok, HO injectors been 1 year, if I understand right... it won't spool enough if there's not enough fuel??
Turbo seems good, no bearing "freeplay" and it does rotate manually very nice. No signs of "wings" touching to base.
Air intake, exhaust's been "open" all the time. Before intercooler it was same, no difference.
Still wondering fuel supply, could it be or is it IP... TDCO is close to -1.6x
There's no black smoke more than before...Sub runs very good but I just wonder why boost has changed.
I have TDScan sw and fuel rate seems the same ~80mm3 WOT what PCM tells.
BR, kane
BR, kane
