Here is a photo I found on Fleabay. the rail it's self is plastic and the silver metal caps look to be crimped on each end. what's silly is there both leaking from what seems to be a pin hole in the center of the crimped on end cap. looking online I only found one post where someone had this issue but never posted a fix.
Someone tell me if I am wrong. this engine is the same as an "LS" engine where I could get an aftermarket fuel rail setup and run it with the stock injectors? only thing I would need is a remote located pressure regulator?
a rail like this ?
Buy HTRACING Billet Fuel Rail Kit Compatible with LS LS1 LS2 LS3 LS6 Stock Intake Manifold 6AN+Hardware: Intake Manifolds - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
and a pressure regulator like this?
