I have a 34 gal tank on the 1993 that appears to only have a working capacity of 24 gal. It never reads over the full mark and in fact sometimes never reaches the full mark by 1 notch. I have filled the tank till I see fuel in the fill neck. I am sure the float can't go all the way to the top due to the vent tube interference.
I have an aftermarket replacement tank and pickup assembly.
Is the MSU leaving 10 gal in the bottom of the tank while reading empty? Is it supposed to read below the empty line? Is the aftermarket vent tube extension on the tank too far down? IE calibrated length of vent tube for 24 gal instead of 34?
My memory is faded but I recall being near empty and taking a couple 5 gal water jugs of bad fuel out of the tank before dropping it with the MSU in place couple years ago or so.
Is this the amount of fuel that needs to be left in the tank to prevent stalling?
