TurboTahoe
Recruit
- Messages
- 790
- Reaction score
- 6
Hi guys. I could sure use some help. Here's the history:
Over the past month, I've been running into a number of irritating little problems on the Tahoe, all manifesting themselves as intermittent, with the occasional DTC thrown in. The list:
* DTC 44 and 45 - the EGR error codes. Sometimes the codes would be thrown and the truck would lose the wastegate solenoid function, resulting in no boost and lots of black smoke, no power. Very scary on the freeway.
* Action Taken: Replaced EGR Solenoids (both of them), and the vacuum harness (because I broke it when replacing the solenoids)
* DTC 29 - The "glow plug" fault - this was also intermittent, and would cause the glow plugs to not function. The truck would start, but would not glow the plugs.
* Action taken: Replaced glow plug solenoid.
* WIF light - Yes, sometimes the "Water In Fuel" light would flicker on, usually under heavy acceleration. There were times when the EGR codes would come on at the same time.
* Action taken: Vacuumed out the fuel filter, checked filter and filter bowl for water. Cleaned everything out.
* DTC 29 came back, accompanied by loss of glow plug light and no glow activity.
* Action taken: After receiving advice from this forum, I cleaned all my grounds, replaced a faulty one, and put in new 4 ga grounding cables.
* DTC 29 came back... again.
* Action taken: After looking at the schematic and thinking some more, I decided to replace the ignition switch. Did that last night.
Today...
Started and ran normally. No codes, no missing lights, no error lights, nothing. Just ran normally. Went off to work, went to number of meetings, ran some errands... and then... got these codes on the way home:
* DTC 29, 31, 42, 44, 45, 57, 62
* Glows will not glow, but Tahoe appears to run normally otherwise.
I'm really at my wit's end. What do you guys think I should do?
Rob
Today...
Rob
